Clear resin plastic toy shader
Hey!
I’m working on a new toy that I will have rapid prototyped and then cast into resin toys, and I am using Vray to test the various colorways I want to be doing. One of them is a clearn resin/plastic like the picture below, often used in Japanese toys:
Does anyone have any tips on how to create a shader like this? What’s the best place to start? SSS materials?
Any help would be highly appreciated :slight_smile:
do u have bigger image?
Yep! I do!
here:
Imgur
aaaand
Imgur
there’s some more toys in his flickr set:
obviously the opaque parts have been airbrushed with paint, but it’s the plastic i’m after.
thanks bazuka! ^-^
here’s the original pic in hi-res:
Imgur
:slight_smile:
nice, if the shader i post doesnt work for u, ill make a new one, based on this pic :wink:
thanks bazuka! i’ll give the one you made a shot! I think it should work reasonably well. I’ll post the results asap :slight_smile:
weeeell, it’s not too bad, but it doesn’t quite seem like a plastic toy… :confused:
The japanese toys are rotocasted, so they consist of a 3-5 mm thick skin making the toy hollow. Both my 3d model and the actual 3d print will have a massive core. So obviously it’s hard to get the same effect from the start when there are these sort of differences… :confused:
To get the same kind of light falloff in the material, you really need to model it like a shell, and then use some glossy refraction and fog in VRayMtl to get that effect.
Yeah that was what I was thinking too, modelling-wise…
The actual physical model of the toy will have a massive core, so I’m better off trying to simulate that look in Vray instead. I’ll throw some fog and glossy refraction on it though.
Thanks Vlado!
yo man, did u manage to make a shell toy?
hey bazuka!
yeah, well, the thing is, the toy will actually not be a shell when I make it in real life, so it’s not necessary to model it like that for me. I’ll just be doing test-renders with the shader you made. thanks for the help bazuka!
nice, can u drop some pics so we can see :wink:
