Clipper slicing other objects
Hi all,
I’m running into an issue with the vray clipper. I have a simple scene with each clipper only including 1 box each. It seems that the second clipper is creating a slice of the 1st box, which is should not be. I’ve been running into this with several different scenes. I’m running 3.10.01.
Any ideas?
Thanks!
It’s a bug, thanks for the report :slight_smile:
Also, would be nice if after you center the clipper in your viewport, you could orbit around the clipper. Right now it seems to think it’s in a different location then where it should be.
