Cloner source objects are rendered when an asset is instanced via Render Instance / Multi-Instance (from 2nd clone on)
Environment
  • Cinema 4D 2026.4.0
  • Corona Renderer 14 HF1
  • macOS 15.7 (Apple Silicon, arm64), M2 Max, 96 GB RAMM
Summary
When an object hierarchy that contains a Cloner is duplicated by an outer Cloner
set to “Render Instance” or “Multi-Instance”, the child objects (clone sources)
of the inner Cloner are additionally rendered, starting with the 2nd clone.
The original object and the 1st clone render correctly. With the outer Cloner
set to “Instance”, everything renders correctly. The viewport is always correct;
the extra objects only appear in the Corona render.
Reproduction scene (attached: Corona_Bugreport_Nested_Cloner.zip)
The scene contains three variants side by side. Each variant has the original
asset on the left and a Grid Cloner (3 clones, Instance mode: Render Instance)
containing an Instance of that asset on the right.
Inside each asset:
  • “Housing” (blue cube)
  • “Source tray” (orange), part of the asset
  • “Filler cloner”: Linear Cloner, count 1, placed on the roof, with two Instance
    children referencing the source tray (local Y = +70 and Y = 0)
Variants:
  • A: simple cube tray
  • B: polygon tray + Instance of a Grid Cloner (render instance) with goods
    from hidden templates
  • C: like B + Cluster deformer on the tray
All three variants reproduce the issue.
Steps to reproduce
  1. Open the attached scene.
  2. Render with Corona (camera and render settings are set).
  3. Switch the outer cloners’ Instance mode between “Render Instance”,
    “Multi-Instance” and “Instance” and render again.
Expected
Every copy shows exactly one orange tray on its roof, like the original.
Actual
With “Render Instance” or “Multi-Instance”, the 2nd and 3rd clone additionally
show the inner Cloner’s child objects: one extra tray floating about 70 cm above
the roof and another one overlapping the regular tray. Original and 1st clone
are correct. With “Instance” all copies are correct.
Additional observations
  • In “Render Instance” mode the outer Cloner’s cache consists of one real copy
    (1st clone) plus Instance objects for all further clones. Only these further
    clones are affected, so it looks like Corona resolves the referenced hierarchy
    without skipping generator input objects (cloner children).
  • A single Instance object in “Render Instance” mode referencing the asset
    shows the same extra objects.
  • In our production scene (a storage lift with ~2,200 objects) this affects
    every cloner inside the asset: extra trays on the roof, overlapping trays
    below the roof and an extra box in the middle of a grid-cloned container.
  • Changing the inner Cloner’s Instance mode from “Render Instance” to
    “Instance” does NOT fix it.
  • Geometry generated by a Python Generator inside the asset (its cache contains
    Instance objects, but there are no child/input objects) renders correctly in
    all clones.
Workaround
Set the outer Cloner’s Instance mode to “Instance”. This works, but uses
considerably more memory with many copies, which is exactly what render
instances are meant to avoid.
Corona_Bugreport_Nested_Cloner.c4d.zip (93.0 KB)
Hi Rene,
Thanks for the detailed report and the reproduction scene.
I was able to reproduce the issue and have logged it with our development team for further investigation.
We’ll keep you updated on any progress or fixes.
CC4D-1499
