After searching around and not coming up with a very good answer to my question, I will try asking you guys. Does anyone know of a good way to create clouds and skies? I am trying to limit the amount of post-processing and photoshopping. I want clouds to be able to be in the background as well as reflect off glass facades, such as the sky behind the camera. Does anyone know a good way to do this besides placing a plane behind the camera and mapping a bitmap?
search around, I’ve seen a couple tutorials using vrayfog but I would use a Vraydome with a HDRI on it. (faster and easier)
Take a look at this: http://vray.info/tutorials/vrayenvfogclouds/
Sorrily it increases rendertime.
As much as it pains me to say it, E-on Vue is actually pretty good for clouds, you can even render out a spherical HDRI as well.
I came back to the same conclusion - how do you find the integration with vray if you wanted to render everything in one pass? A big factor is can it take correct motion blur?
My personal preference is to render out an HDR from vue and a backplate and use this like you would for any pboto match. this means you don’t have to usevue xstrem.
I getcha - one thing I’ll be looking at quite soon will involves objects flying through volumes though so it needs to be able to join together handily enough.
I have looked into Vue9 before too and I just don’t think it is in my budget. It did look pretty cool, but on the PLE of it, I always had problems with it using VRay as the renderer. I will take a look at this tutorial.
Well you could buy the Ozone product which is basically just the cloud part of Vue.
Heya
I’ve struggled with clouds for a long time. And the winning soft was vue in max n vray.
I can render out 10000x6000 pixel size renders with clouds in about 1h using only dual quad core xeon e5530.
Its pretty funny how 3ds max n vray can get it rendered in 1h when vue itself need…weeks…
GL
