CMasking RE & Layered Material
Just discovered what I take for a very annoying bug … it seems there’s no way to output a Material ID from a layered material using CMasking render element :frowning: only the Base mtl is output, and not correctly, since the layer materials’ masks aren’t respected !
Any chance to fix that for v2, please ? very very annoying …
Apologize if it has already been reported - I’ve quickly searched and didn’t find any report about that.
Thank you,
Regards.
Do you guys need a scene to show the problem ?
Thank you.
We already have this logged, along with other layered mtl improvements. Sorry, but currently there is no specific time frame when we could expect it.
Internal note: id=192606087
Hi Maru,
Thank you for your feedback. Sorry for the double reporting then, I still don’t have the reflex to checkin Mantis first …
Really, this MatID limitation with LayeredMaterial is very annoying, I hope this can be fixed for v2 :wink:
Regards.
EDIT: are you sure about the ID ? no way to find this on the bug tracker.
It was about our internal task tracker, which is not available publicly. It’s not Mantis.
And that was also an internal note. :wink:
Eheh ok thank you !
