We’ve been doing a lot of BLACK features on our projects, such as Door Panels and other intricate items that end up looking like a BLOB of BLACK in renders. Seems like changing the color of outlines to a gray would help this out TREMENDOUSLY… I am also on board with assigning a LINETYPE to this feature to achieve SKETCHY outlines. If this VOTING THING works… please enter your agreement…
3Hi Duane,
I’d like to understand the look you’re going for before we take this further.
Could you share a screenshot of one of those renders, and if you have it, a reference image of how you’d like it to look instead? A sketch, an older render, or an image from another tool all work.
It would also help to know who the images are for and at what stage: internal design reviews, early client presentations, or final deliverables.
The Enscape team
Here’s an exhibit of the concept… where black materials contain some DETAIL.. like slats in a garage door, it will help us show this detail. I can see it useful throughout the process… Help clients see intent, help contractor get a better picture… help governing agencies assess the look… etc.
You can also see that it helps explain areas in deep shadow like the upper soffit.
We would like NOT use this for renderings or EXE’s… but more an more we are including “screenshots”, etc in our construction documents…
The idea would be for me to be able to MIX the color per PRESET…
Hi Duane,
Thanks for putting the mockup together. The garage door slats and the soffit show the problem far better than a description could, and it’s useful to know these images end up in your construction documents, not only in client renders.
There’s no setting in Enscape today that gets you this look. The closest workaround is to export a line drawing of the same view from Archicad and lay it over the Enscape image in post, which may well be how you built the mockup.
One thing to keep in mind: coloured outlines would share the catch black ones have today. A white or grey line is just as hard to see on a white or grey material, so choosing the colour per preset, as you suggest, would matter.
We’re leaving this open to collect votes, so anyone who needs the same, please upvote. We’ve noted the line type idea as well.
The Enscape team
Enscape Team, Yes, I agree that there are times both will have issues, but it seems to the casual observer (me) that this is a fairly simple add and allowing the CHOICE would offer the BEST of both worlds....
– DGD-Duane
BTW... if you wanted to offer the option of LINETYPES... like sketchy, etc... I wouldn't say no...
– DGD-Duane
