outlines ....
hi
can i ask to add outlines for selected material ? it will be very helpfull for tiny details ofc with different thickness of that lines because last preview version cannot do different outline thickness…
thank you .
Thanks for your inquiry @jan1 , this has already been requested before so I’ve happily given the corresponding feature request on our agenda a further upvote through your voice. Also, due to multiple requests we’ve implemented equal outline output correspondingly, would you like to have the ability to switch back to how it was before that? :slight_smile:
well i need freedom of choice , if some1 wants thick outlines ok , if another persom wants OL to be thinner let him allow it … i mean variability of OL thickness by that slider.
Thanks for the feedback @jan1 , I’ll forward it accordingly! :slight_smile:
hello Demian
i found one other request for out lines , is there a way to add some checkbox for adding OL on plain /flat/ but divided surface ?
@jan1 Currently this is not possible. We only support outlines at corners of the geometry.
hi there,
outlines again… i only can secont the requeste from the thread ..
and add another request on top → make “outlines” visible when there are seperate objects …
we often use boxes or simplified geometry for furniture etc.. its a pitty when the outlines are not shown when you have surfaces that are perfectly aligned…
it would really help the “illustrative” character of the rendering if there was outlines for the separation of materials and objects :slight_smile:
thanks,
best
franz
Yes seeing outlines between two coplanar faces with different material would be nice!
