Coloring VrayProxy with Vertex Color
I have an 500 frame animation of an object meshed with Frost and colored with Vertex Color.
When I convert it to a VrayProxy it doesn’t pick up the VC anymore.. Are there any workarounds?
Hm, works fine for me on a regular mesh so I’m not sure what might be wrong. Does it work if you use another mapping channel rather than the vertex colors?
I did some more testing, and realize that the proxy only picks up the VC from the original mesh when I use a standard material.. If I assign a VrayMaterial with a Vertex Color map to the proxy, it simply does not turn up in the render at all (no alpha channel either)
It worked fine in my test with a VRayMtl material. Is it possible to get us a scene for this to vray@chaosgroup.com
Hey Vlado,
I tried again in a fresh scene and now it’s working as intended…
Thanks..
