Well there’s always a bit of adjusting, but you adjust the lighting to your desired levels, and then tweak textures. If I use the vray sun, I think I lower it down to something like 0.05 intensity, and don’t worry about the camera settings. If I’m using other lights, then their values are just adjusted to suit.
No, I have it turned off. For me it’s just another variable that I don’t need to deal with. I don’t use camera exposure, then the lights and materials from each scene will work well in another scene. Plus I balance the brightness with the light values. For me it’s more artistic too.
I think the sun is the killer, and lowering the intensity seems to help. If I want to boost it in a post, I can do so by using an element.
Here is one that I got pretty good on the first try: the colors seem to work with no adjustments in post. The sun’s turbulence was adjusted to 5, which I think helped. I also used real world camera exspoure.
Not sure how using exposure or not affects the realism of the render. You can do it with exposure or by adjusting the light values— just like in a real photo studio, or like using ND or scrims outside.
Some sort of filmic style tone mapping can be used with either method. Most vray tools seem to work more easily at their default settings with the exposure method, though.
I prefer EV exposure, since I want to set shutter speed and aperture for artistic reasons. So EV is just like using ND or changing film speed.
I find it easier to have a base, so I use real-world camera settings, including lenses. This way, I am not guessing. I think part of my issue is my HDRIs. Using V-Ray Sun/Sky seems more straightforward to manage. The image I posted above is real-world camera settings and the default sun/sky, except I changed the Turbidity to 5. All other V-Ray settings are default.
Hey Bobby - out of interest, do you use the Reinhard Burn Value in the Color Mapping roll out? Say, setting it to 0.5? This has the effect of clamping down over-bright areas
I save all of my work to iCloud Photos, and I love what Apple’s autocorrect does to my images. The pop it gets is fantastic, but it downgrades the file size and compresses it, so it can’t be used other than looking at it on social shares and the iPhone. Often, I use Photoshop to match the iCloud version to my version, but it isn’t as good. PhotoShop’s camera raw is okay, but it’s not as good. The Topaz Photo AI destroys my images; do you know of a way to auto-correct on the iPhone without compressing it to a smaller size? Here is Apple’s iPhone auto-correct version.
I do more realistic renders that non-realistic. For me, realism is largely down to materials and form, and lighting is what gives the image style and interest. Putting a vraysun and a physical camera into a scene doesn’t make a realistic render.
I disagree, Vray sun and a physical camera coupled with a good tone mapping produce quite accurate results, and this is not surprising since all modern render engines are based on physics.
I’ve done several comparisons between renders and real dslr photos and results are always pretty close.
Here for example I’ve used physical sun and a Vray camera, later I’ll upload some real photo of the room: https://forums.chaos.com/forum/chaos-common/chaos-common-gallery/1202964-renovation-of-historic-apartment-in-florence
Here, an early render test and a photo made with a good reflex. Nothing but Vray sun/sky(default setup and intensity), a physical camera with the same exposure of the reflex and some basic tone mapping (white balance, highlight compression and a photographic LUT):
Dont get me wrong, vraysun and such can be used in great images, my point was (and perhaps unclear), is that you cant just drop in a vraysun and expect your shot to look realistic, the materials and forms need to be realistic before lighting.
For me, I prefer the control other lights give me, such as spot, directional, dome, etc give, rather than being tied into a sun system. But that’s just my preference.
When trouble shooting images, I have a simple process -
Does it look “right”? If not check modelling (scale, proportions, accuracy).
Does it look “real”? If not, check materials, shaders. Are these are real as possible.
Does it look "interesting? If not, check lighting, balance and contrast, and composition. Is the lighting and composition correct for the shot.
9/10 this process works and helps narrow down the process.
