sorry but i still get the error on composit rc2 build, max 2015, simple scene just a plane with composite, with regular and corona bitmap and coronaAO material, with regular and corona bitmap alone its ok.
doing some tests and its the corona AO material, i used the mix with corona AO as sub mat and put to show on viewport , it crashed again.
I just fixed bug in CoronaAO when shown in viewport. Try just using coronaAO in composite - it should also crash (even when not using CoronaBitmap)
yes, it crashes max 2014, max 2015, corona AO on any sub map you assign, i know the corona AO doesnt have a show in viewport option itself but when its assign on any material it crashes.
yes, the button is grayed out, because CoronaAO tells 3dsmax “I dont wanna be displayed in the viewport”, and 3dsmax respects that by greying out the option. But as soon as you put CoronaAO inside composite map, composite says “screw you, you are gonna get displayed either way, bitch!”. CoronaAO is not prepared for that, hence crash. I fixed it in time for 1.1, so tomorrow release will fix this.
jaja ok, perfect
