anyone else had this issue?
started my computer this morning and Max wouldn’t open due to Corona demo being out of date.
Logged on to Corona site and saw commercial version was available so bought a license.
Installed 1.00.01 and now none of my scenes will work with Corona Render selected. Max menus and dropdowns seem to work but viewport frozen or blank.
do you use CoronaColor texmap? If yes, try the latest daily build, there was one related issue fixed in it: Daily Builds 1.0 - 1.4 - Corona for 3ds Max :: Previews (Daily Builds) - Chaos Forum
no, haven’t used coronaColor but will give updated build a try
thank you
maru
March 2, 2015, 12:31pm
4
Activated it straight away.
When I open a scene, it seems to run ok (viewport seems to work) until I open the material editor, then it all goes wrong.
This is a real disappointment after paying for a subscription.
is it easy to revert back to the free version?
…after viewport crash, max will not close properly and comes up with an error message after closing.
lius86
March 2, 2015, 2:23pm
9
I got a different problem, as soon as i click anywhere in the corona buffer, max crashes.
Max 2015 64 bit.
Standard Autodesk error report
“A software problem caused 3ds Max to close unexpectedly”
unhandled exception
I’ve noticed that the material editor doesn’t just black out the sample slots like it does if you’re using an incompatible renderer, or haven’t activated Corona, instead it looks like it’s waiting to load them and they’re just not coming up (showing white not black)
Can you post the minidump it creates? (See https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006 ) It would help me with debugging
for example here: Renderer for architectural visualization - Corona | Chaos
be sure to post here the full filename that will be displayed after you upload it
just uploading a dump data zip called 1425377550_dumpdata_mommus.zip
second file is 1425377601_3dsmax_minidump.dmp
thanks for your help
ok thanks, I will take a look later
sorry, I am out for 2 more days, then I will take a look
haven’t been able to do any work this week - are you any closer to a solution?
I’ve tried to roll back to the free version but max will no longer start
sorry, I am travelling this week. I won’t get to it before tomorrow evening
maru
March 6, 2015, 2:49pm
20
