Condensation
I’m looking for a way to recreate the very specific condensation in the attached.
Tyflow seems the way to go but I’m finding it tricky to nail the settings to describe the layout and form of the droplets.
I’d be extremely grateful for any help with this one, as I’ve a lot on and it’s eating up my time trying to brainstorm it :slight_smile:
I suppose I’m hoping that, as usual, as soon as I post I suddenly find a solution, but just in case…
Still? Maybe just bump / displace / normal? Google Search
Animated? Then tyflow or something similar is an option. Or find footage of condensation on glass, and use that as a texture map, or in post.
Thanks.
However I’ve been in this rabbit hole for days and scoured the internet for resources, none of which is useable for this, sadly.
These are stills at a very high resolution, so need to work perfectly close up, as close to the reference as possible.
They are full bottle shots, so any repetition is easily spotted.
Bump won’t cut it, neither normal, so geo is the only real option.
Tyflow is the most promising but it’s proving tricky to get that referenced variation.
My tests involve one flow of spherical drops and one flow of blobmeshed ones for the irregular type.
The issue is how they mix as one, again following that reference, so any ideas that work towards this would be great.
Currently, using the above concept I’m trying to find a b/w map method that can separate the patches, plus the probable 1 in 1000 permutations
that make the blobmesh behave properly in the gaps.
Just thinking more about this, although I do think I have a solution, quite randomly.
Is there any type of noise that can be forced to do what I need, i.e. to have a base that is irregular but the peak transition to rounded?
I mean, noise is maths so surely there must be some control to make that happen.
The attached is the normal map I eventually found and which does a pretty decent job of replicating that reference.
The person that made say they did it with Modo, so it’s procedural, hence my above question.
If I can get a tweakable method of doing similar then that would be ideal.
