Content Browser
I have the problem with the content browser when I have objects with multiple polygons and save them, the content browser preview shows the display in black. But if I connect all polygons and then save the preview will be displayed correctly this error only occurs with Vray material..it would be nice to fix this problem as soon as possible I would like to edit my assets for Vray 5!
Thank you very much
This was reported a long time ago.
Also waiting for this to be fixed.
Hi there!
I work with the content browser. I think it is a must that the preview works!
Don’t any of you use the content browser?
This is a known issue and it has already been reported to our developers. I will let you know once we have more information.
They say it is normal that some basic stuff could be bugged or missing in a official release…
In the meantime, let’s raise the price
- welcome to vray
Hello
It is very important that the content browser with Vray 5 works with VrayBitmap.
IWould like to edit my assets for Vray 5.
According to the picture I have created murals for Vray 5, how should you make the right selection for the pictures if you can’t see anything?
a related question, how is itmeant to have displacement stored in the content browser?
if i set materials to be saved in content browser the displ tag isnt stored,as it isnt a mat?
only if a put a full place holder object with the tag on it, but this always also loads also the object into the scene which is unwanted, not just the material.
any insight on how you thought the displacemn tag is used in material libraries woudl be great:)
thx!
Hallo!
Gibt es vielleicht Infos bis wann der Inhaltsbrowser funktioniert?
Dankeschön
Hello @Wohnraumdesign ,
I cannot provide you with a specific timeframe for when this will be fixed. It has been reported and I will let you know when we have any updates on the matter.
Deleted - senseless
Thank you!
i never understood why displacement can not also be a material channel in vray.
not always, but mostly you want it in conjunction with a material, not?
Displacement is the simulation of real micro inequalities on the surface, this is not actually a material property (I think so :roll_eyes: ). I understand that this reasoning behind the separation of displacement into separate material. Moreover, having displacement on separate material can be beneficial, it can be handled separately. Although I admit that displacement as a channel in the material also at first glance seems more logical and I also did not get used to separation for a long time. Of course, if everything works as it should. 8)
The main reason why the displacement is in a tag and not in a material is to preserve compatibility and interoperability between V-Ray integrations.
Hi
I would like to know if there is any news about the Vorschau in the content browser, because i can’t work with the current preview in black,and probably not everyone else either User!
Thank you very much!
Hi @Wohnraumdesign , we made some fixes regarding the relative path names used in v-ray objects (including VRayBitmap). Since this was the main problem for the black previews - I suggest trying the latest stable nightly build if it works for you (nightlies/stable).
Thanks for the information!
I just tested the latest nightly build from 20210312
Version 30654 but nothing has changed, the objects still remain black?
Funktioniert nur mit C4d Material bei Verwendung von Vray Material wird alles schwarz!
Can you give an example scene with the asset and material you are trying to save in the Content Browser, so we can investigate further? Also it would be helpful to know the exact version of Cinema 4D you are testing this on?
Schicke Ihnen eine Testscene
