How to convert a 3ds Max Corona 7 project to Chaos Vantage for animation using the V-ray converter that cant convert corona main Physical material?
Are you using V-Ray 5? Seems that support for the new Corona physical material was added in V-Ray 6.
Hi @npg
I am using the latest version of v-ray 6 ! And it still gives errors! Any suggestions?
Assuming you’re getting errors from the converter - you should ask on the 3ds Max section of the forum. It’s not a Vantage issue.
If there was Vantage for Corona, that would solve the problem.
