Copying V-Ray Color Ramp node crashes blender
Hello!
To reproduce the bug:
  1. Create a material
  2. Add the V-Ray Gradient Ramp Texture;
  3. Select the V-Ray Color Ramp node and Ctrl + C.
It will also crashes Blender if you select other nodes and Color Ramp and try to copy them.
V-Ray 7.40.01 rev 659 / Blender 5.2.2 LTS
Yeah, I’m running into this issue as well — at first I assumed it was because my Blender had too many other add-ons installed.
Working on fixing this at the moment, there were some major changes in recent blender versions on how copying nodes is handled. We had noticed this previously with some of our nodes, but I had no idea this also happens with the gradient nodes.
Thanks! I have two other questions.
Do you think it will be possible to have this and the output path corrected for the next nightly build?
and
Is there any place where we can check what was corrected/changed for each nightly build? or at least the most recent?
The path thing probably not. This crash will likely be in stable by the end of the week. I have been meaning to add change log generation in nightly builds, but we are also migrating some internal stuff, so I have been putting that off as it will a bit of a waste.
