We have just released bugfix version 1.00.02, available to all customers.
It fixes these problems:
- Licensing server is now a 32bit application, and has an option to run without UI (with -n commandline switch)
- Framebuffer sidebar is now on by default
- Fixed some crashes/freezes when parsing geometry
- Fixed wxWidgets assert and/or crash when starting Corona
- Fixed crashes (error -1073741795) when starting Corona
- Fixed crash caused by displaying CoronaColor texmap in viewport
- Fixed “error 127” when loading Corona on Windows Vista
- Fixed error causing different frames being rendered on render nodes than on master when using DR
- When running without a license, material editor will now show it is missing a license instead of rendering black
- Changed default sensor width from 35mm to 36mm
- Fixed a bug sometimes causing Corona Scatter not to be displayed in the viewport
- Fixed Corona VFB spinners not being usable when system decimal point and thousands separator are set to the same character
- Fixed crashes when using XRef-ed scene containing CoronaSun
- Fixed bug sometimes causing Corona Scatter to report negative polycount values.
Licensing, outputs, compatibility is exactly the same as previous build. We advise everybody to update. Get the update here: Renderer for architectural visualization - Corona | Chaos
