I found Corona 10 to be very laggy and slow on different facets of the engine. I’ve opened an old scene that rendered in 1h15m in C9. With C10 it is almost two hours. Quite unacceptable if you ask me. Also the IR is buggy. Hangs when making changes to lights etc, and when trying to stop the engine then it seems to stuck.
Maybe I can upload one of my scenes for the devs to look at?
Scenes are always welcome, they can be attached to a ticket Chaos - also do let us know your hardware configuration too, in particular CPU plus RAM configuration. We are looking in to some similar reports too, so the more scenes and data we get, the better we can see what might be happening. Thanks!
I’ve made a ticket and uploaded the scene. As I do a lot of bottles with heavy use of caustics, maybe the new caustics solver has to do something with it?
When I want to revert to Corona 9, can I simply grab that installer or do I need to remove Corona 10 from the system first?
I’ve been running 10 for the past 10 days and i had the same feeling of renderings being slower. This morning i replace 10 by 9 and re rendere my scene. With 10 its really slower then with 9. 1 hour 50mn with 10 vs 40 mn with 9.
Configuration :C4D/CRN Windows. AMD Ryzen Thread Ripper 3990X 64 core. 256 Go RAM
It’s a pretty simple scene. A terrasse with some furnitures. A few plants. Some maxtree bamboo. Multipass rendering in 16bits. 5000x3750 px. On HDRI. Noise target to 5.
Hi.
I’m using window 10 last update.
I can’t share the scene now becaus it’s under disclosure.
But since sunday, i’ve done a lot of other renders andt it’s the same. Faster with 9. Around 2 or 3 times.
I think there is an issue with the triplanar / mapping randomizer (either one or in combo) which takes a lot of computing power. I also saw similar reports in the max forum.
There is a fix for the triplanar slowdown being tested in the Max daily build right now, with the aim to have this hotfixed in Corona 10 for Max and C4D soon (along with C4D 2024 compatibility, for the C4D hotfix).
I tried again V10 this morning. I renderer the exactly same scene with 9 and 10 (see captures enclosed). Still the same : 24mn 34 s for CRN 9 Vs 52 mn 19 s for CRN 10.
I’ll send a ticket with the scene to support.
Somthing elsei’m not happy with : The help isn’t up to date wit CRN 10. Are we talking about a professional solution?
Have anoce Week-end.
Is there a solution coming for the triplanar slowdown?
We rolled back the renderfarm and workstations to C9 because C10 is unusable slow with the triplanar shader.
I wonder why you don’t have 40 or 50 different scenes or short animations for quality control, each testing specific requirements and combinations.
Then, with each new release, you would render all those scenes once and suddenly find that one or two of them are taking a long time to render, or something looks different than it did before, and so on.
That way you would at least find out obvious things like that. But for us customers to try it first and then complain here in the forum is not optimal. We are customers, not testers. We pay for the software and are not paid to test it.
And as an aside, we do indeed have a variety of test scenes and other QA tests that all releases go through. Those are continually modified as well when necessary. Even with that, we can’t catch everything - but this is not at all the same as expecting our users to be testers; we do our due diligence very carefully before any sort of final release.
A hopefully helpful PS too - be sure to follow the News section on the forum, and / or our social media on FB, Twitter, and Instagram, as we blast out hotfix news there. You can also follow the daily builds, which is where the earliest examples of fixes show up (though we understand with production work going on, not everyone can risk installing a daily!). Thanks!
I’ve noticed a quite significant slowdown when upgrading to R9 to R10 also, so much so that I’m considering moving my whole team over to another engine.
When I get some time I’ll re-download R9 and do some comparisons.
I’m running C4D 2023, Corona 11 (I was hoping it would be better that 10 but it’s not) on a Mac Studio.
Did you put all used bitmaps inside a CoronaBitmap shader?
In one of my scenes where the rendertime went up from 1h20 in C9 to 2h28 in C10 I’ve managed to get it down again to 1h40 by just using the CoronaBitmap shader for (most of) the bitmaps.
