We recently upgraded our Corona-Render from version 14 to the latest version 15, and have encountered an issue related to proxy usage.
After the upgrade, users are only able to sign in successfully when bypassing the proxy. However, after each system restart, the same issue reoccurs and we are required to disable or bypass the proxy again for login to succeed. This behaviour was not present in version 14, which worked reliably with our proxy configuration.
We have not made any changes to our proxy settings or environment during this upgrade, so we would like to understand:
- What changes in version 15 could be causing this behaviour?
- Are there any known issues related to proxy authentication or connectivity in this version?
- Is there a list of URLs, domains, or endpoints that should be excluded from proxy inspection or added to a bypass list to ensure consistent login functionality?
Any guidance or documentation you can provide would be greatly appreciated.
Steven
