Corona 4 and proxy files
Hello guys,
So, after installing corona 4, I open a project that I’m working on and some objects (objects that i create and make them proxys) do not appear on the viewport and in the render. I try to open it in other workstations (with corona 4) and nothing, same. The path of asset tracking is correct and the proxys files do not have been modified. Any idea?!
Just to say that this work never brought problems with proxys until i installed corona 4. Any ideia to resolve this problem?
Ok guys, so a solved the problem by installing de previous version (corona 3 hotfix 2). So, any admin of Corona to see this problem with Corona 4??
Can you please provide your scene and assets?
Instructions on how to do this are here Chaos. Please don’t forget to let me know the name of your files.
Thanks,
Rowan
Hello rowmanns,
I will sent the file - 1560777590_IHT-File-MAX.rar
This file do not have proxys but in corona 4, i open this file and the objects are gone (only a screw stays). If you open the same file in Corona 3 (hotfix2) you will see every objects.
Thank you for reply
OMG Sorry, i do not put all files, here it is:
1560780865_IHT-File-MAX.rar
So sorry :frowning:
Thank you very much for reporting this to us! I was able to reproduce this issue with your scene.
We will look into this asap.
Thanks,
Rowan
(Internal ID=364321606)
Thank you for the help.
Waiting for news :smiley:
Cumps
Hello again,
I’m working in another project, and i tried to create a proxy from some trees. So, when the trees are converted to proxy, we only see the leaves, the trunk do not apear in the render.
Cumps
there is a new Corona hotfix, to download. It solved most of the problems i had with proxies. Perhaps it solve yours.
