Hello I still struggle to get corona uv randomizer with displacement and multiple elements to work.
It always is random offset to each map… even though the uv-randomize settings and seeds are exactly the same
Is it still a known problem or is there something wrong on my set-up?
I’m using latest corona 7 release with max 2020.
It looks ok - if i set everything in the uv-randomize-map to “no randomize values”
