Hello guys,
Today i’ve used the Corona UVrandomizer for the first time since release 7.1.
With 6.x it always worked like a charm, and now, same scene, it no longer works (as instance mode), see picture.
Any idea ?
Regards.
You didn’t show full material tree, i suspect you plugged maps in the wrong order. If there’s Corona triplanar between randomizer and material, try to swap the two maps and see if that works.
Obvious question but got to check, are you sure those are instances? (the geo)
The tree is only some color corrections, and some AO.
The geometry is instanced.
Fact is that this scene was working like a charm with corona 6.2, and now UVrandomizer with the same scene does not work as it did before.
I’ll try to move the UVrandomizer in the tree, to see if it changes.
If the issue persists, please feel free to send us an archive of the scene so that we can further investigate.
We could not reproduce this and I am not aware of any similar reports. In case of some issues with the UvwRandomizer, please let us know.
