Corona 8 not render Multi-instancia native c4d
Cinema 4d R25 multi-instance objects not rendering.
Passing them to render instance if they are rendered.
The same file with corona 7 if you render the multi-instance objects.
macOS, c4d R25.117, Corona 8
It must be a punctual failure or my mistake in some layer. Multi-instance works fine.
Hi, can you please supply us with your scene for testing?
Instance activating multi-instance doesn’t work neither with corona nor with native cinema render. It seems to be cinema error. However, when I use the cloner and activate the multi-instance, everything works perfectly.
