Corona a6 + forestpack pro big problem
Hi, i’m using 3ds max 2014, corona a6 and forestpack pro 4. I’m using forestpack for the first time, but everytime when i try to render anything all materials from forestpack are red with big “doublesided unsupported material” sign. How can i fix it? It’s really important for me.
There is the scene (low resolution), this red section should be a grass.
Well, double sided materials are not supported. So you have to convert them to something Corona can render.
You can change to single with translucency. I’ve seen some serious grass around the forum with those.
I’ve converted using coronaconverter v0.17, but now everything is overexposed, even when I set the sun on 0,01 and environment on lowest possible value.
Edit_1:
problem partially solved.
I had to set hosek&wilkie sky model, multiplier 0,1 ; turbidity 1,7 ; use vraysun (coronasun is to bright even with 0,01), but there is a lot of work to make it look good.
ok.
Set exposure in exposure tab to -5
