Corona Batch Render with Different Material Option Fully automate
Hi everyone,
I’ve been working in the furniture industry and am looking to set up a batch render using a single camera to create multiple renders with different colors. Currently, I render one image, change the material colors, and then render again.
I’d like to find a way to automate this entire process so it runs without manual input.
Thanks!
You could put your materials in a multisub then animate the material ID with a modifier. If you need fabrics separate from woods then you can either detatch or use sub-selections etc.
Then render an image sequence instead of a single frame.
You can also use Corona select material, i think it can be keyframed as well.
… or select map if it’s just about the material color (yes, both are keyable).
Good Luck
