Corona Bitmap and UV-Randomizer Problem
I’ve got a problem with the Corona Bitmap in combination with the UV-Randomizer.
When i use a C4D-Bitmap the result is randomized.
When i use a Corona-Bitmap the result is not randomized.
In my Test i just changed the C4D-Bitmap with the Corona-Bitmap Node. All other parameters are absolutly the same. What is the problem.
I send 2 Pictures an the C4d-File (with Diffuse-Image)
My Sys-Config: MacBook pro 16, 2,4 GHz 8-Core Intel Core i9, 64GbB Ram, MD Radeon Pro 5500M 8 GB, Monterey 12.6.6, C4D R21, Corona 9 (Hotfix 1)
Greetings, Wolfgang
UV-Randomizer-Problemc4d.c4d (208 KB)
Hi there, I tested your scene and was not able to reproduce your issue. Both C4D & Corona bitmaps randomized as expected. Could you please try using a newer version to see if that helps?
Hi Beanzvision,
after the upgrade to Corona 10.2 the UV-Randomizer works.
Thank you!
You’re most welcome! We’re glad to hear this.
