I have been evaluating the Cororna Render and I really like it.
from last few days I was rendering few shots with it works just fine but I come up with two issues
Cororna crashed 3dsmax on 4 shots, so i have to start max and start the render again from where it left. it only completed one shot without crashing.
Cororna didnt crashed 3dsmax but on any random frame it just keeps calculating, I waited for hours but it just keeps doing it, where render frame time is just one minute. so I have exit 3dsmax to restart it from that frame.
is there any workaround for this problem, or is it too early to expect stability from corona.
by the way i am using the Ver - 1.0 on 3dsmax 64bit. except corona I only have vray installed.
Is this a “heavy” scene (lots of objects, much RAM needed)? Are you using displacement? The frames where it keeps calculating - are they different in any way from the frames that render normally?
I am using latest version - CORONA RENDERER FOR 3DS MAX 1.00.02
There is no error message when it crash, it is just a typical windows dialogue that comes in.
The scene file is very very light only 8000 polys with corona sun lighting the scene. no displacement, camera is moving through it nothing unusual, the crashing behaviour is with 4 scenes with complete different setup so I guss no problem with geometry.
as I said if I restart it then it renders fine until it crash next and so on.
there are 2 options when using process explorer - to create minidump and regular dump. If you created minidump, it would be only few megabytes. But you can still upload even the huge one, if you have fast enough internet - you can use Renderer for architectural visualization - Corona | Chaos
