CORONA DENOISER (STAND ALONE) + DENOISER ISSUE
Hi Corona Devs,
Q1: Do you plan to make Corona Denoiser Tool (standalone) app just what live Vray have?
-or you already have it, I don’t where to look for it
Q2: Why is it RE-DENOISING in Corona Image Editor have much better outcome than in VFB inside 3Ds Max?
(Corona High Quality denoiser was used) - see attached file
…Why not put this nice feature inside VFB?
thanks guys
Did you use the firefly removal option in Corona Image Editor - and if so, does it match the Max VFB output if you disable it? That could be the reason why it works better in CIE.
Hi Pokoy,
I can’t recall if I use that FireFly Removal then ReDenoising it in CIE.
Will take note of what you have said. Thanks
