Corona Image editor Crash
Hello, on the attached video you can see what happen if I run the Corona image editor and I close it without do nothing.
I segmentation fault crash appears.
This happen with corona 9 and previously release on OSX.
Alex
Hi there, can you also test this on the latest V10 daily build?
Dear B, sorry I’m under a deadline so I can’t try the R10. This issue happens since corona 5 was out on OSX…:joy:
Alex
If you use Custom, you can turn off everything except the Image Editor for install. That will mean you aren’t changing your Corona version in C4D (just disable all the C4D checkboxes) - should work, afaik. Or you could unpack and just update the CIE.
This happen also to me, since memorable times. Tested Also on OSX Ventura 13.0 Corona Beta 10
Crash Log Attached
Cheers
Crash Report.txt (93 KB)
I think that developers never opened this app in their life…
