Corona Proxy Exporter (continuous updates)
Well, in this case it’s worth a regular bug report for the corona team to look into :smiley:
Hi, the converter told me to post this here…
ErrorReport.txt (654 Bytes)
Hi, this is not quite the correct thread but anyways, the problem in your case is a very old Vray version that is not supported by the converter. If you upgrade it, it should work again :smiley:
This might be only a big deal for me only but I have some complex models with a bunch of Falloff maps set to “Shadow / Light” that corona doesn’t support and render correctly. Can there be an update to the converter to convert all those Falloff maps to Fresnel instead?
