Corona Render 9 Hotfix3 Crash after save all image render but Not CXR render
Hello everyone,
I have a recent problem that is the same on two different 3dsmax Scenes.
After rendering a scene with Corona 9 (Hotfix3), I can easily save the CXR file from the button located at the top left of the window BUT if I save all passes 3dsmax crash.
I specify that if I open the CXR (recorded from 3dsmax) with CoronaImage.exe and I try to save the passes I have the same crash
Also, for a very short time, I have also had this error message when opening my 3dsmax 2023 file.
Do you have any idea where this could come from, if so I thank you in advance!!
Have a nice day and thank you,
Julian
Corona 9 hotfix3 - 3dsmax 2023 V25.0
My first troubleshooting question would be: are you able to reproduce the same crash in Corona 10 HF2? Download | My Chaos
Other than that:
  • Do you have enough HDD space to save all the elements?
  • Do you have enough available RAM during the element saving process?
Regarding the error message from your screenshot - that’s a 3ds Max message, not Corona’s. Judging by the G: letter in the path, I guess you are using Google Drive and this may be the culprit. If it’s not causing any issues, I would say you can safely ignore it. 3ds Max shows similar errors even if you open files through Windows .lnk shortcuts…
Hello, any updates here? Have you tried with V10 HF2?
