File open dialog changed from 3ds Max dialog to Corona’s one in all 4 usages - CProxy, CoronaLight ies file, CoronaCam lut file, and ColorCorrectTex lut file. The open dialogs now remember the current file path and open from there.
Added support for RailClone 4 segment materials
When opening older (pre-v5 scenes), when there is no displacement used, Corona automatically switches to 2.5D displacement. We still ask for permission when there is any displacement used, so that scene appearance does not change without user input
Optimizations - CoronaBitmap - Optimized memory storage of textures whose dimensions are not a power of 2. 20-30% total memory reduction in few real world scenes we tested.
CoronaBitmap - Up to 66% memory reduction when using RGB textures that hold only gray colors
Improved performance of Density map slot in Corona Scatter (e.g. speeds up common setup with Corona Distance map plugged into it).
Bugfixes - Fixed the “update to 2.5D displacement” popup lowering screen size of an instanced displacement modifier multiple times
Fixed scatter not updating viewport when scale map mode is changed
Fixed LightMtl using wrong UV coordinates in some specific cases
Fixed blurring of caustics at the edge of the screen
Fixed crash when scene is reset while docked IR is running.
Fixed crash when caustics are used with native 3ds Max regions
Fixed randomized assigning of materials in RailClone
Fixed Corona Scatter not to recompute on changes in material of original model objects (could cause freezes in some rare cases)
Changes - Introduced a new way to activate corona - you can set your email & password or a path to the licensing server to environment variable CORONA_ACTIVATION: - For email and password, use format “email:password”
For licensing server address, use format “LS:address”
Material dispersion Abbe number minimum value changed from 10 to 1.
Added render stamp token %ptg which is replaced with the scene geometry preprocessing time (in milliseconds).
Removed perfect backwards compatibility of very old CoronaMtl. 5+years old Corona materials (Corona 1.2 or older) might now render slightly differently.
Temporarily removed Corona Standalone from the installer. We’re currently doing a full rewrite of the Standalone code and it will be much faster if we don’t need to maintain full backwards compatibility in every step during the development. The new version of standalone will be ready for v6 release.
Bugfixes - Fixed vector displacement not working correctly when no specific UV channel was specified
Fixed crash when creating Corona Scatter in 3ds Max 2016 (and possibly earlier) while Corona license is not active.
FallOff map in distance blend mode in 3ds Max now renders in Corona the same way as in scanline renderer
Fixed issue where light mix/postprocessing settings in VFB where not accepting values if mouse was outside of the VFB window
Fix of crash of layered material with empty rayswitcher
Fix of reparsing suns everytime during IR - should be done now only when some sun is changed
Fixed Corona toolbar not to possibly cause 3ds Max crashes during its shutdown on fresh Corona installations.
Removed support for 3ds Max 2013. This 3ds Max version is barely used anymore and maintaining it took too much from our time which could otherwise be spent on making new features.
Added new adaptive environment light sampler based on the one in V-Ray - Noise clears up to 2x faster in interior scenes in general; up to 9x faster in certain extreme cases.
The new solver is now used as default for all new and old scenes.
This solver should remove the need for portals in most scenes.
Fixed the updated material library not working with 3ds Max 2016 and older. Note that this fix is applied retroactively and the previous daily build installer will download this fixed version as well. - If you are using the offline libarary file you will need to download the new one here
Removed portals from CoronaCore - Portals are no longer needed because of the new adaptive environment sampler which fully replaces them.
The portal material is now deprecated and won’t show in the material editor.
When opening a scene with portals, you will be notified that they are deprecated now and can be deleted.
Fixed adaptive enviro sampler together with shadowcatcher producing artifacts
Fixed crash when rendering with Phoenix FD version 4. Corona now supports both version 3 and version 4 of Phoenix FD.
Fixed crash of VolumeGrid when Checker map is assigned
Fixed sometimes incorrect evaluation of scale map in Corona Scatter when the map is switched to Object XYZ or World XYZ mapping. Legacy scenes remain unaffected unless the Legacy switch gets turned off.
Toolbar now correctly shrinks (both horizontally and vertically) when some of its button gets removed via context menu.
Added displaying of name of the sun that is linked with the sky when the sun selection is set to automatic
Fixed crashes when Corona Sun is disabled
CIE now saves JPEGs with quality 100 (and not 98).
Added “Dissolve with previous image” to IR controls in Render Settings Devel/Experimental rollout. - When unchecked, the rendered image is refreshed only after the first pass has been finished. This is the current behavior.
When checked, the previous image will be kept and will be gradually replaced by the new image during the first pass of IR render. This was the original behavior from before we introduced IR subsampling.
Fixed dispersion being disabled for low GI/AA values
Added (randomized) tiling support to UvwRandomizer map - You can specify how many tiles to make in each (U-V) direction
Optionally each tile can have a different randomization applied
Added Improved lens effects - These include aperture editor accessible from Corona VFB
16-bit textures now take 2x less memory
IR now makes 3ds Max UI less laggy when “Dissolve with previous image” is enabled
Made the effect of “Conserve memory” checkbox more pronounced: memory reduction is increased by up to 18% overall, but also speed decrease is up to 30% bigger overall.
Fixed Crash when using bitmap with Corona Volume Mtl in “inside volume” mode
CIE UI updated to support the new lens effects
CoronaConverter - fixed outdated link for error reporting.
Added “Size” parameter, controlling the size of Bloom and Glare, to Camera/Postprocessing tab.
UVW randomizer now takes into account the UV scaling of the input maps. This allows better handling of real world scale textures.
Lower memory usage when denoising is not enabled
Added option to disable caustics adaptivity/optimizations. The option should be used in the case that issues associated with caustic solver appear (black spots in caustics pass, disappearing caustics).
Fixed issue of Improved Sky model with strange spot appearing below horizon with large horizon blur.
Added high quality blending into the UVW randomizer - Greatly increases the quality of result especially on the tile boundaries at the cost of slower computation
Fixed textures mixed with Corona Mix not rendering in Phoenix displacement
Improved scene export to better handle scenes with many (scattered) instances.
Fixed handling of LightMix and exclude lists for scattered instances in export for standalone.
Improved performance of parsing scenes with many instances.
The behavior of MultiMap randomization is now consistent with V5 (except of Forrest Pack scatter).
Fixed producing of NaNs in rendering after baking LightMix
Fixed crashing of proxy when rendering
Bloom and glare “Size” parameter in the CoronaCamera is no longer editable when the legacy bloom and glare is enabled
Improved error handling when invalid command line argument is supplied to LicensingServer
Fixed DR crashing when mr_prim is enabled for hair & fur
Added support for 3dsmax Mix map mixing curve feature
When starting a comparison with render history in VFB, the comparison vertical line is now initially always drawn in the middle of the visible area independently of the zoom level
Corona Scatter no longer freezes UI when recomputing in heavy scenes, also when using Corona Distance map in density slot. - UI of the scatter is generally more responsive and performance is greatly improved.
Loading scatter scenes is faster (on average by 28%, in extreme cases by 78%, depending on number and size of textures used in the scenes and number of scattered instances there).
Also fixed the viewport not updating when changing time on the timeline in some cases.
Fixed the viewport not correctly displaying instances in some cases.
Fixed rare cases of different scatter results between master and node in DR environment.
Added support for psd files during conversion between max/corona bitmaps to Corona Converter script.
Improvements - Improved 4K cache precomputation speed, leading also to faster IR
Autobump is now turned on if the user clicks on the warning message about 2.5D displacement and if the scene is older than Corona 3.
Noise level is now not shown in VFB when using “Render only masks”
Corona toolbar now uses High-DPI icons in 3ds Max 2017 and newer.
‘X’ menu (global search menu) now offers actions from the Corona toolbar and keyboard shortcuts can be assigned to them.
It is possible to add 3ds Max’s buttons to our toolbar and vice versa.
Removed Corona’s top bar menu from 3ds Max (the functionality is replaced by Corona’s toolbar)
Bugfixes - Fixed issue where rendering with Blowup mode caused 4K cache to generate too many records.
Fixed crashes in some corrupted scenes
Fixed crash when using CoronaColorCorrect map with curves
Fixed issue where instances generated by MultiScatter were not scattered when distance map was used for density slot.
CoronaDistance map “no object” shader no longer changes hue with different EV
Fixed issue where user could not use hex input in CoronaColor map.
Fixed incorrect computation of opacity when CoronaColor map is used in the opacity channel
Fixed black artifacts in the CTexmap render element when AO map and materials with opacity are used
Fixed issue where native Max VFB was not refreshed during rendering
Fixed: Incorrect gamma error message not showing in logs
Fixed: Editing curves in CoronaColorCorrect map during IR causes the IR to constantly refresh
Fixed adaptivity when parts of the scene are excluded (using render selection, etc.).
Fixed a bug that caused that using render element with no filtering may have lead to incorrect accumulation of other render elements.
Fixed wrong evaluation of render elements when using opacity.
Fixed issue where one could not use linear interpolation for curves in CoronaColorCorrect. Selecting linear interpolation led to reverting back to cubic and restarting IR twice.
Fixed crashing when using CoronaColorCorrect and CoronaUvwRandomizer with “Randomize each tile” and “High quality blending” enabled
CTexmap render element is no longer propagated as masks
World displacement size is reduced by 1.5 if 2.5D displacement is enabled in the warning log for legacy scenes.
Optimized user properties storage in geometry. This should especially help in speed and memory requirements when parsing “extreme” scatter scenes.
Added standalone export support for 3ds Max ColorCorrect map
Added standalone export support for 3ds Max Falloff map
Added clamping of light mtl intensity to ensure that the value is really between the min max specified in the paramblock (Could have been raised higher by max script or baking light mix).
CoronaColorCorrect - Curve interpolation mode is no longer changed when hitting reset button. Also interpolation mode is correctly displayed when changing curve type or loading curves.
When opening older scenes, CoronaUvwRandomizer blending weight will be set to 0 instead of the default value 0.25, to preserve old behavior and prevent any performance hit. - Unfortunately due to a glitch this also resets the blending weight in all scenes saved prior to this daily build, sorry for that.
You can use the attached script to quickly set blending of all CoronaUvwRandomizer maps in a scene to a specific value. By default it sets everything to the default value 0.25, but you can easily edit this value at the top of the script.
Further optimization of precomputation of 4K Cache - Speedup is up to 2 times in normal rendering, up to 6x times in IR (when just moving camera)
We’ll be continuing with more optimizations in further builds.
Fixed issue where light mix values were randomly overridden
EULA changes: - Added notice on the use of trademarks and other logos belonging to Chaos Czech or its partners (article and updated our privacy information with a reference for a further reading to our Privacy Notice (article 15).
Otherwise we did stylistic and technical changes allowing the EULA to be used with other software we may provide.
Refactored Bezier curves support in Corona. This gives better match of curves between Corona Standalone and 3dsmax for e.g. Output map
Added reporting of warnings & errors during 3ds Max map substitution
Added option to reset the settings in the new bloom & glare aperture editor
Fixed CoronaColorCorrect connected to bump slot not producing any bump when brightness adjustment was set to 0
Changed the new bloom & glare default size to 15
Toolbar starts even in first session of fresh install (or after ENU folder removal) of 3ds Max 2017 or older.
In Customize User Interface toolbar actions moved from Corona to Corona Renderer category.
Deprecated Corona top bar menu is now properly removed during 3dsMax startup.
Bloom & Glare “custom aperture” editor checkbox is grayed out when disabled
Warning is shown when rendering masks only with noise limit (when pass and time limits are not set)
IR subsampling and “dissolve with previous” options moved from devel/experimental rollout of render settings to system settings. This also means that these options are now per-computer, not per-scene.
Edit:
I forgot to mention one important update - we’ve added anonymous product usage statistics to Corona. This will allow us to make more informed decisions where to focus our future efforts, knowing which features are used the most. It is enabled in default, but you can turn it off/on in the very first screen of the installer and/or later from 3ds Max in the System Settings dialog.
In short what we’re gathering is:
Which components are selected in the installer. I.e. how many poeple do install CIE.
Which versions of 3ds Max are used and with which plugins.
What resolutions are rendered and what types of objects are in the rendered scene.
Some statistics about the finished render - ray/s, memory usage, number of unique/instanced primitives, etc.
To see which data is gathered in detail you can use the “Save message preview to a file” button under the “Product usage data” section of the System Settings dialog. This button will save product usage messages generated from the current 3ds Max session to a human readable text file. Even when the product usage data sending is currently disabled, you can still use this button as a preview of what would be sent if this was enabled. changeCoronaUvwRandomizerBlendingValue.ms (304 Bytes)
Added possibility to add secondary GI precomputation time into VFB render stamp - with %pts
When the environment is visible through a reflection or refraction during mask propagation, the result is now a black color instead of the mask of the reflecting/refracting object.
Fixed crash when saving scene with Corona Scatter switched to point cloud display mode.
Fixed freeze when loading some Corona Scatter scenes.
Fixed material library layout when displaying materials with long names
Fixed crash when modifying material in the material editor while IR is running when “Enable material editor” option in the IR section of system settings is disabled.
Fixed issues appearing in light material (exclusion and black enviro after hidden in mask works for light material now)
