Hello! I have a problem with Corona (1.6) Scatter in 1D-mode: any changes can crash 3DS Max (2014).
Hi, can you provide us with exact step by step instructions of what you are doing and what happens?
When it crashes, please create a minidump file and send it to us: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006-how-to-report-issues-
I just create Corona Scatter, change 2D to 1D. Select a spline to distribute on it, and then select some objects (in some cases these were autos in other tree models). And then absolutly randomly Max crashed on any other changes, e.g. changing name of Scatter or Rotation, or any other manipulation.
3dsmax_minidump.dmp (3.51 MB)
Corona 1.6.1 - problem still exists
Looks like the crash is in Corona Scatter indeed, however the developers will need to take a closer look at this.
I was not able to reproduce this issue.
I had the exact same problem on 2014 with this one for example: Meadow Asset *Making of available**cscatter-version available* - Corona Common :: Gallery - Chaos Forum .. but also every simple thing crashed with max 2014 - corona 1.6.1. Maybe a service pack update/downgrade would solve it.. haven’t tried it yet
On 2016 scattering works fine.
Same here, corona scatter, max 2014 crashes continuously.
I updated everything it still crashes, did you find anything? I’ve already sent minidump. Corona 1.5.2 works just fine, tested all scatter features..
We have received some minidumps, so stay tuned…
It seems that this happens only in Max 2014, so upgrading Max would be one solution for now.
Solution to this Max 2014 + scatter crashing is already in our internal builds, and it will be included in the 1.7 release.
fixed
Thanx! I can’t test daily builds on work, so waiting for 1.7 release ![]()
