Corona 1.01 (45 day demo) crash 3ds Max 2014
Hello! Faced with this problem:
I set Corona 1.01 (45 day demo) crash 3ds Max 2014.
This error occurs when I cancel reneder, quite spontaneously.
It happened after the conversion stage of Vray, to corona alpha 6.1 there was no such error.
PS.: Percent amd Phenom II X6 1055T, 3ds Max 2014
i have same error i have AMD 1055T plz fix it fast :frowning:
Please, provide as much information about a problem as you can: https://coronarenderer.freshdesk.com/support/solutions/articles/5000524006
i just upload 3dsmax_minidump.dmp on [ Corona Uploader ] iam using 3dsmax design 2015 64x and did clean install on 3dsmax 2016 same problem the dump file from 3dsmax 2016
ps: when i was using corona Corona_1.00.02 its was fine but when i started to use Corona_1.01.00 it started to happen >> one more thing this happen only with big scenes small scene didnt happen and notice when i click stop render corona start to {saving + cleaning up} then crash maybe this will help thx for all your works realy GREAT JOB with this engine
my pc specs :
plz any progress with the fix i need it badly :frowning: dont want back to corona 1.0
I found the problem in the minidump, I will upload fixed version shortly
Try the latest daily:
ya ty it worked i still have 3dsmax 2016 tho i download the fixed version you attached above and rename it - Corona2015.dlr > Corona2016.dlr - CoronaUtils2015.dlt > CoronaUtils2016.dlt - it worked all fine now ty agian hope all the best for corona future :smiley:
Hello! Thank you for what was found and corrected the error. But the simple renaming of files in * 2014 produces an error when loading 3ds Max. Please download the corrected version of 3ds Max 2014. Thanks in advance!
installer will be released soon (today hopefully ;))
