Corona Sun / Corona Sky are not working on new project
Hi:)
I have a problem using Corona for Cinema4D.
When I add Corona Sun and/or Corona Sky they don’t seem to work (See images). Even if I increase the intensity or scale the sun up, nothing changes. Even if I only activate Corona Sky, for example, I get a similar result.
(I created the file and didn’t touch any other settings)
What do I have to set to make it work? Thank you for all replies :smiley:
It might be too obvious but did you set the renderer to Corona?
That was actually not set, thank you very much! But even if I activate corona in the settings, only white appears instead. If I disable Corona Sun, the poorly rendered cube appears again. Is there another reason
Lower the exposure.
For outside scenes with just corona sky you’ll need to drop to about -3
