Corona Trial Run
Hi Guys,
Finally took the plunge and installed corona Alpha5 yesterday and after getting my head around a bit of the workflow, here is the result of my first image. I haven’t let it go long at all (186 passes at 2000x2000 which took an hour and a half on my 2 x xeon) but I think the results are REALLY good considering I spent NO time on materials (and left a lot just as a test material) and lit the scene with an HDRI and 2 material portals.
For anyone interested, the settings were PT16 and HD Cache50 and I upped the secondary GI settings to PT512 with 300max records. Perhaps these changes were unnecessary but I tried to collect a few tips from suggestions within the image gallery from users that had submitted the works I liked.
I’m really interested to understand corona a lot better with the view to switching over from Mental Ray as soon as possible so please, C and C as well as pointers would be more than welcome.
P.S…I have attached a 2nd image with the stats bar up because I would like to better understand the lights section. It says I have 22,843 lights. I noticed that in the Aplha4 benchmark test there was only 1 light indicated. Have I done something terrible here that I need to be made aware of? :smiley:
OK SO MORE THE NUMBER OF RAYS/S MEANS LESS THE GRAINY RENDER WILL BE?
I MEAN MORE RAYS/S = LESS GRAINY RENDER ?
Each polygon from light-emitting object is counted as a separate light. Don’t worry though, it will render reasonably fast most of the times even with high light count :wink:
I figured it was going to be a geometry/poly thing. Thanks for the clarification Keymaster. Appreciated :smiley:
oh no i wasn’t screaming i was rendering something on after effects so capslock was on and i didnt knew capslock means screaming hehehe i just googled it :tongue:
anyway i was trying corona on my vray scene i converted it using dead clown converter which worked great and the render looks grainy
so should i let it run for like 80-90+ passes ?
it wont be grainy then ?
i used a daylight with corona sun and sky :smiley:
thanks
There is no rule for this but in most cases you should be able to have acceptable results after about 100 passes.
[/quote]
[/quote]
yes i got it now . getting the hang of it . thanks :smiley:
