I’ve got a scene which when rendered with version 1 is coming out massively over exposed. Opened the same scene on another machine with 7.2 and its rendering correctly (as previously). Checked all the settings and they all seem the same. Except the output im getting is different.
Am using a vrayhdri shader with for the sky environment, not sure iof this is the cause or not.
Is there a camera with CoronaCamera modifier in your scene? The exposure controls were redesigned so maybe you need to switch to photographic exposure in render settings?
I think it might be due to the VrayHDRI. Tested with normal corona sun and corona sky, and i get the same result. Tested again with a standard hdri as the sky (no vrayhdri) and i get the same result.
Eventually solved this with the help of Mr Peter Guthrie. The only value that corona seems to be ignoring is the ‘Render Multiplier’ in the VrayHDRI shader.
We had a similar problem at work when opening previous corona scenes and eventually noticed the render multiplier was not working in the vray hdri loader anymore which is annoying need a corona hdri loader!
Have noticed another issue though and wondering if you guys have encountered the same problem. When converting scenes from v7.2 to corona v1 with the same settings we are noticing a lot more noise or lack of samples particularly in the direct light from the hdri this seems to be an issue when there is more corona lights in the scene, is there a max number of corona lights now or something wrong with vray hdri loader? Have started increasing the light sample multiplier which seems to help a bit but can’t understand why I should need to increase this when previously default value of 2.0 worked fine in v7.2 version?
