I just wanted to upgrade to Corona version 14. But after installing I cant open 3dsmax anymore. It crashes instantly on startup. Im using 3dsMax 2024. Also attaching the minidump.
3dsmax_minidump.dmp (4.71 MB)
Thank you for the report. I can see that you have also contacted us over the support portal in ticket #438104. We will continue over there and share our findings here once we understand what is going on.
Good to know there are others with the same issue. I’ve got an open ticket dealing with this but just want to share on here some findings.
When I merge an older 3ds Max file from Corona 12 into a fresh 3ds Max scene with Corona 14, It merges everything fine without crashes.
As soon as I tick ‘render settings’ on the merge with the same above process then max crashes.
I’m thinking something to do with the render settings not translating well from Corona 12 to 13/14
This happens only on some files, not all the time.
I’ve just had a Corona 14 scene crash upon opening even though I was working on it before in Corona 14…
