Hello!
VFB periodically disables image editing capabilities.
Sometimes the cursor stops changing its appearance.
This is because you are overriding Tone mapping operators from Camera.
Regarding the cursor changing appearance, can you explain it a bit more what is exactly happening?
Hello! It looks something like this. The cursor does not change in the image field, not when you need to enter digital values. Always a palm. The problem with HF1 remains. Occurs when memory becomes low.
Stuck cursor issue has been discussed here: https://forum.corona-renderer.com/ Pan Hand pointer (always) corona 12 Try to see if you can find some solutions over there.
