I have CoronaInteractive in one of my viewports, rendering away fine. I then launch a proper CoronaVFB Render to test how it looks at higher res and let it finish.
At this point nothing else should happen, but what does happen is that the CoronaVFB immediately disappears and the Interactive session starts up again. If I then hit the ShowCoronaVFB button nothing happens. If I close the Interactive session I still can’t recover the CoronaVFB.
In other words, the Interactive is killing the main VFB render completely and is non-recoverable.
If I launch the CoronaVFB Render without using Interactive first, all is fine.
Note also that if I maximise my perspective viewport (the camera view), so the interactive viewport is not visible in max, and then launch a VFB render, the same thing happens. The render completes fine, but then the VFB remains open. but as soon as I minimise/restore back to Quad view, the Interactive viewport launches and the VFB is closed and the render lost.
I am also having some issues with the Interactive renderer not updating and only showing the result of the previous session, even after starting a fresh session.
All of this is known but apparently hard to fix. To see the content of your regular VFB, you can go to rendering > rendered frame window. This will show natie max vfb with your last Corona rendering inside.
The thing with interactive showing result of previous session - does it get fixed after you restart IR or move any of the objects in scene?
Ah yes I forgot it was saved somehow in the max FB as well. At least the render is somewhat recoverable. (although I assume only the beauty pass. other passes will be lost I guess). hope this can be fixed soon…
Maybe for now it should be made that Corona will automatically disable the current Interactive Session when you hit Render. Could this be done? Or at least a warning popup?
As for the locking Interactive window.. I just opened a fresh max instance, opened my scene, started an interactive session and it’s jammed after just a few seconds. seems to be scuck on some kind of pre-calc stage. No amount of jiggling things around in the viewport fixes it. EDIT: it seems not to like one of my cameras. All other cams are fine… weird.
Ok I think I found the issue. It’s a bug. Using PhysCam, if Perspective control is on, say a vertical lens shift, AND you’re using target camera, Interactive doesn’t work. If you disable either the target OR the lens shift it works.
To be even more specific: only shift is causing the bug. tilt doesn’t cause a problem and interactive updates fine.
I just checked and everything works fine in 1.2.1 and daily build. Or maybe I am doing something wrong. I switched to the camera in that file, enabled targeted and shift. IR updates fine docked and floating, regular rendering works too. Also created a new camera and did that, works fine again. Would be great if someone else could check this.
To be honest I’ve had a LOT of weirdness with Corona and max this last few weeks. Who knows, really. Today I had a load of QNAN black spots in my scene and nothing causing them at all, then I restarted max and re-rendered and they were gone (nothing changed in scene at all, so I think this is related to not clearing the VFB between renders…), objects randomly disappearing and being moved in max, all sorts of things…
