CoronaVolumeMtl animated noise?
Hi everyone,
First of all thank you for taking the time to read this, and even more so if you spend any time thinking of a solution!
So, volume light and scatter in Corona is easy enough, few clicks gives you very decent results, however! I don’t know if any of you remember the good old scanline max standard way of doing it, but you had the option to animate a noise, size of your choosing to break up the volume light and simulate dust and other particles.
How would you go about doing this in Corona? using Corona volumemtl? (or standard corona mtl for that matter).
Cheers
