I’m having issues downloading certain assets from the Cosmos Library. They hang at 98% and the download never gets finished.
I updated my computer with a brand-new C: drive (SSD) and Windows 11 64bits. Not sure if it has something to do with the OS since it was working fine one Windows 10 64bits.
Thanks!
-Fausto.
Mind if you attach the cb.log file (located here: C:\Program Files\Common Files\Chaos\Cosmos) after attempting to download?
Sure thing!
I just tried uploading the log, but I got this msg:
Can I email to you?
Thanks!
-Fausto.
Could you try downloading again? Our devs implemented a fix that may have resolved the issue.
Sure thing, thanks so much for looking into it!
I will keep you posted.
Quick question, is there a way to install the Cosmos Library only? Or do I have to re-install V-Ray?
Thanks!
-Fausto.
The old V-Ray Material Library is now integrated in Cosmos, so no need to download it. Otherwise, in older versions of V-Ray, there’s the mtllib.exe (C:\ProgramData\Autodesk\ApplicationPlugins\VRay3d sMax20XX\bin\) with which you can re-download it.
Or am I misunderstanding the question?
You understood perfectly, thanks so much!
I also tested re-downloading the assets that were not working before, no more issues! Thank you so much for the help!
Best,
-Fausto.
