The grass models in cosmos, why don’t they have two sided materials, which we normally use for foliage. It’s an issue I’ve been facing in sketchup, when trying to set a scatter with cosmos grass, I couldn’t place the sun opposite to the camera, because the grasses won’t let sunlight to penetrate through, resulting in a thick dark green patch. One solution is to create a new two sided mat. and merge the cosmos asset and assign new material. Is this a bug or is that the way its created?
This test render shows that difference. Left image with manually created two sided mat. Right image, default cosmos asset.
Hello @thanish_afridhi ,
Thank you for your report. Our colleagues will look into it and if there isn’t a significant difference in the performance, we will update these assets. I’ll let you know if we have any new information.
Kind regards,
Iva
Thanks for the response.
In general, the entire vegetation catalog needs looking at when it comes down to translucency.
I would like to inform you that the assets are updated in the latest Cosmos Browser version.
@DanSHP if there are specific assets which are not rendered as expected, please let us know.
Thanks again!
Kind regards,
Iva
Thanks very much. The updates were perfect !!!
