Cosmos materials crash Maya 2024
Hi, anytime I try and import a material from Cosmos library it crashes Maya 2024. I know that its known to be incompatible with Arnold. There used to be the same issue importing assets form cosmos but this works now.
I’m on Maya 2024.2 and the latest Vray 6, so I was hoping it would work together by now.
It’s suggested to disable Arnold , but whenever I try, it crashes Maya! It works on a fresh, clean scene, but then needs disabling with all your Maya scenes, and then just crashes every time… I’m just stuck. I dont want to have to uninstall Arnold as I do use it as well as Vray
How has everyone else overcome this? My Arnold is 5.3.4… there is an update to 5.4. Will this help?
Many thanks!
Hi, thanks for posting. I am able to reproduce the crash. Turning Arnold off from the plug-in manager prevents Maya from crashing. We will see if there is anything that can be done on our side to improve the situation.
I have arnold turned off / disabled / unloaded in plugin window but cosmos assets still crash maya when I try to view scene textures. Even with cosmos assets hidden in the outliner.
Linking threads.
