Cosmos People in my model is shown like seen through “fisheye lens” in Vision, but the rest of model looks right - what´s wrong You think ? My view is NOT through Glass. Sketchup Pro 2021 and Vray 5 on Win 10 64 bit.
Hello, @kimalbech ,
Thank you for this report!
Have you made any transformation (or any other action) to the component prior to launching Vision or while it is running?
If you are able to reliably reproduce this model’s distortion in Vision, could you please share the scene with us for further investigation (https://www.chaosgroup.com/help/cont…cene#options?)) You can copy only the Cosmos asset if it is sufficient to produce the faulty result.
@Peter.Chaushev Not sure what You mean - I have the Vision window of the scene i the attachment ! It´s not limited to a single Cosmos model - It´s all Cosmos people in my model.
By “scene”, I meant the project .skp file.
Does the issue occur with other project files (even newly-created ones)?
What is the full version number of your V-Ray for SketchUp (visible by opening “Extensions > V-Ray > Help > About”)? The latest is v5.10.03.
If you are using an older version, please visit https://download.chaosgroup.com/?lic…248&product=47 to download the latest one. An issue similar to what you illustrate was fixed recently.
If the issue persists with v5.10.03, please provide the following:
- the skp file from your screenshot. You can pack it using the SketchUp menu “Extensions > V-Ray > Pack Project” (exclude the Cosmos assets to reduce file size).
- The Player.log file located at %UserProfile%\AppData\LocalLow\Chaos Group\V-Ray Vision
