Placed some cosmos content to try them out in a render. The rendering looks just like I would expect, but when I load up vray vision, the scaling is huge but flattened.
Hi @cnd7jones ,
We’re aware of the issue and have been working on a fix. By chance, have you rotated those assets using the Objects tab rotation?
Best,
Ana
Ana, i think i only used the space bar during placement to rotate them. I did try mirroring in revit and noticed it only mirrored the revit geometry and not the vray proxy.
We’re working on a fix. I’ll keep you posted.
So it is supposed to contain artificial lights, am I getting it correctly? Have you enabled those lights from the respective button on the V-Ray toolbar? (there is a button for enabling artificial lights)
And another question - have you enabled automatic EV in Vision itself?
Yep you got it sorry…Yeah, have both Artificial and Vray Sun enabled. if i turn off exterior lighting and just leave on the interior it’s starting to look correct just no bounce lighting. and yes autoexposure is turned on. i thought if i turned down the multiplier on HDR/Sun it would work but not doing anything.
Oh and to be fair, i guess it doesn’t have to have “bounce” light but, any type of ambient + direct would suffice.
Well, I made a simple test using Revit’s basic sample project with a light and an hdr from Cosmos. I tried with both Sun and Dome light, with reduced intensity. In Vision, besides that the EV is set to auto, I also adjusted the exposure compensation parameter which can be found under the settings menu.
Both examples are attached. Oh, and I also adjusted the environment light position in Vision (by holding the Ctrl key plus moving the mouse left-right/up-down with its left button pressed).
So, I assume there could be something in your scene that hasn’t been setup yet. (May be you can send it over for a quick look at ana.lyubenova@chaosgroup.com)
