CPU powers drops
I have an issue on a very simple scene made of a few walls and a ceiling, timber floor and a coffee table.
It is lit by a Corona Sky environment map. Every objects are assigned a simple plain grey CoronaPhysicalMtl.
When I hit render (production renderer), everything works as expected: the cpu runs at 100%.
But as soon as I apply the ‘White Paint’ material to an object, the cpu usage drops to around 40%.
If I get of this material and I apply back the grey neutral material, the cpu usage hits 100% again.
The same problem arises if I use the IR.
I can send you the scene if needed (3ds Max 2023.3.3, Corona 10 hotfix 1)
Thanks for the help.
Could it be that the material uses the Triplanar map somewhere?
You could be running into the problem with this map recently reported here for v10:
[https://forum.corona-renderer.com/ CPU/thread performance drop with Corona Triplanar ](https://forum.corona-renderer.com/ CPU/thread performance drop with Corona Triplanar )
Thanks for letting me know.
Duplicate: https://forum.corona-renderer.com/ CPU/thread performance drop with Corona Triplanar
We have just released a new daily build of Corona 11 with a fix for Triplanar map performance issues. You can find it here:
https://forum.corona-renderer.com/ Chaos Corona 11 for 3ds Max - Daily Builds Changelog #msg217142
Please test it and share your results with us.
