I want to add displacement on edge of a model. For this, i use VRayDirt with “invert normal” on, and in the occluded color, i connect my map.
The problem : Vray crash.
V-Ray: V-Ray for Maya version 2.25.01, revision 19321 from Feb 13 2012, 07:40:14, linux64, Maya 2011.
(perhaps now it is fixed on more recent build ? I will test today when i will have the new install at my work)
I don’t know if the VRayDistanceTex do what i want.
I use VrayDirt with normal invert to get the edge of my object. Can we do this with the VRayDistanceTex ?
And the VRayDistanceTex is not in Maya..
Unfortunately it is not fix-able. (Well, we could fix the crash, but it still won’t get you the effect you expect). As Thorsten pointed out, it creates a dependency that cannot be resolved. One solution would be to bake the VRayDirt texture, and then use that as displacement.
Yep, i will bake the VRayDirt, this is the solution.
Just a suggestion/idea : what do you think to add an option in the VRay dirt to bake the map internally before to rendering (like a “prepass”) ? (Renderman style heyhey)
this smells like the ideal application for baking into PTex!!! Does Vray support that already? This would be even more awesome than baking into vertex colors!!!
No, we don’t have any experience with PTex writing just yet; also, we had to implement texture baking for subdivision surfaces first, before we can think of PTex baking (which would have to be be an entirely separate baking engine).
