I’m trying to work out the best workflow for using cryptomatte in post. I’m a bit confused on best practices or how to use it with the layers or name or heirachy selection whilst using objects with multi/sub materials, or using chaos scatter objects and also objects behind transparency, e.g. objects seen through a window. Could anyone shed some light on this? Thanks!
you can always check the guide “How to use the Corona Cryptomatte - 3ds Max”: https://support.chaos.com/hc/en-us/articles/4954305024529
Please note that so far, Cryptomate cannot be propagated through reflections or refractions.
Also, would be perfect if you provide a little bit more information about what exactly you want to achieve when talking about using objects with multi/sub materials, or using chaos scatter objects.
I assume you would like to have a mask (for postproduction) for scattered objects? In this case, I can suggest using a render element “CMasking_Mask” with Manual Selection in RGB mode.
But anyway, would be great if you can better describe what you want to do and achieve ![]()
Sorry I probably explained poorly.
It seems that in the V-Ray version you have an option for cryptomatte ID Type: Material (a version as seen here How to use Cryptomatte Render Elements in V-Ray for SketchUp | Chaos)
Even soa academy explain the ‘best’ practice in vray is to use ID Type: Material (Pagina non trovata | SOA Academy)
Whereas in corona there is no such option. When will this be available? We would like to have our cryptomattes seperated by material i.e. wood_01, wood_02 etc (just example naming)
This then adds to the second question, that if I have an object with 2 materials, multi mat, would cryptomatte ID Type Material work?
And again i guess that would answer the 3rd question, if i have multiple scattered objects would it pick up the ID Type Material?
I was under the impression that cryptomatte was created to more or less ‘replace’ / automate the masking process thus not having to manually assign RGB
Hopefully this makes sense?
Thanks!
