Cube VR 6x1 not working correctly in VFB
I have done all the stereoscopic settings and chosen the camera type as cube 6x1 in Vray tab of the render settings. Resolution is 18432 x 1536 (12:1) ratio. But the resulting render is always showing white spaces and the cubes are all over the place. Any ideas? Is this a Vray 5 bug? I have the latest version installed.
Can you forward this scene or a sample one that reproduces the issue to support@chaosgroup.com (make sure to mention this thread in the email) for further investigation? Thanks!
I’ve solved the problem! The issue was due to the Camera being a 3DS Max Physical Camera instead of a Vray Physical Camera… I switched back a Vray Physical Camera and it rendered fine.
