I currently attached a custom library from one of my coworkers to my enscape/computer. Models appear fine on Revit, I’m able to edit them and I see them in my library. Only issue I’m having is that I can’t see these models on Enscape. (Only about 5 random ones out of 60)
Methods I’ve tried to fix it
Generating all assets
Placing custom assets in different parts of the model
Changing edits to the asset.
Restarting the computer
Opening and closing the model
Hiding and unhiding objects
How can I fix this issue?
Jumping on this thread with the same (or similar) issue. Families native to Enscape are not visible in the Enscape environment, but are visible in the Revit model. I am using Enscape build 3.0.2.44009. My coworker was able to successfully open Revit and see everything in Enscape and is using the previous version of Enscape.
RESOLVED
-Make sure your Enscape is up to date to the latest version.
-Go into the model and place items (or just leave the ones already located in the model. I reapplied them just in case.)
-Once all Items are generated on the asset editor, close escape and the model, then reopen again.
- All models should reappear once you open enscape.
Hi @Maria33
Glad to hear you already resolved the issue.
@ronrandell
Welcome to our forum!
Could you try if following Maria’s steps resolve the issue for you as well?
